- 18 Oct 2002
how is it 'not cheap' to change isp. it costs nothing and there are loads of companies offering good deals.
Yes they can, BT Retail is different to BT Wholesale.
Move isp. I would recomend that you consider Eclipse over at eclipse.net.uk they have looked after me for several house moves, line problems etc. Have to say that over what must be 8 to 10 years they have been brilliant.
Are you 100% sure? I can't imagine the situation an engineer would go to your house, test the internal wiring for faults then pronounce everything fine without running any line/connection tests with their equipment.
Are you LLU? That often causes hassles with intermittent faults as BT blames ISP hardware and the ISP blames BT cabling.
I connect through my BT line to C&W LLU equipment in the exchange. My connection sometimes drops out when receiving phone calls which it never did when I was on BT equipment.
It is a fairly rare but well known problem which it can be improved at the cost of connection speed but the only real cure is to move away from C&W.
It happens infrequently enough that I can live with it as I'm otherwise very happy with the service.
If it started becoming more frequent and no solution was forthcoming I would change supplier.
Are you running any phone extension cables in your house? We had a few of them and they destroy your internet. Drop outs every hour or so and worse speeds. If you are then remove them now and plug your router directly into your filter and then phone socket. Then just extend the cat5e cable if needed.
Have you done the quiet line test? What's you attenuation looking like and what's your SN Margin?
No nothing like that. They meant to be one of the most reliable ISP's in UK.Let me guess. Talk Talk?
I remember reading that they joined with Tiscali, and Tiscali are the single worst ISP out there.
Change to BT, then they can't pass you around between companies playing the blame game![]()
They're under no obligation, according to the contract you signed with them, to do so.
It's residential broadband. The contract will state you cannot use it for business purposes, and that you cannot claim for losses incurred through loss of service.
As you say, the contract has some form of SLA (48 hour disconnection), but you admit yourself they have not breached this agreement.
I'm not a solicitor, etc., but I fail to see any grounds for a case against them.
Check you've got the latest version of whatever DSL hub your ISP provides.
My in-laws had this with BT, until I found out they had received a new hub but hadn't bothered connecting it!!
The only odd thing I find about this thread is that you've been having this issue for a year now.
I had nothing but problems with Sky when moving onto their broadband, two months later and after threatening legal action I had a full refund, compensation, and was signing up elsewhere.
£42?
You're doing it wrong.
LOLOP...sorry but sueing an ISP??...hahahahahahahaha....deep breath.....hahahahahahaha
Oh dear god...just change your isp fella...much less hassle and headache for u and your wallet as well.
Have you tried a quiet line test to see if there is any noise on your BT phone line? 17070 option 2, if so, that could be causing intermittency.
What other equipment have you tried? Alternative router? If so what make/model/firmware?
I had a similar problem, however I also have 4 phone points in the house, 8 months of arguing with BT about this and 6 engineer visits (no fault found in my house - always blamed the exchange) and it turned out to be a faults BT Homehub. Total of 34 calls logged with BT, god knows how many hours on the phone to india but it's now sorted. Exact same symptoms the OP has.
It shouldn't make a difference which ISP you are with. If they use ADSL Max it all goes through the same BT Wholesale equipment. The ISP is basically a reseller. As the problem is line dropping the problem must exist somewhere between your router and BT equipment in the exchange.My local exchange is just a ADSL Max. Who can provide a reliable service within ADSL Max?
Is your current ISP helpful? Are their staff following up your problems or just fobbing you off?
You could try changing ISPs to one known for good customer services.
I meant make a difference to the fault you have.It seems that it does make a difference. Some ISPs block certain protocols etc.
I live in a village and I don't really have too many options... also switching IPS'a would be to easy for them.
I had the same problem. Gave my ISP (Yorkshire...) 3 months to sort it. Just bouncing back and forth between their tech support and BT Wholesale. Switched to an ISP who had a better relationship with BT Wholesale and problem was solved and has been trouble free for 3 years.
If you move from one ADSL Max ISP to another you still have the same physical phone line plugged into the same hardware at the exchange.
It annoys me when people live out in the sticks then moan about their internet connection and expect tax money to get them up to speed,
Don't live there if you want to benefits of urban life
