Not for me, in the same way a 2 wheel drive Porsche 911 is not for me thank-you very much!
I don't want any car that could kill me just because I made a silly mistake.
All cars, then...?
Not really, better than applying a load of counter-steer or hitting the brakes.
All cars, then...?
If on cup suspension, its hard with very little travel/give. If you're going down a bumpy road at speed its gonna skip around quite a bit. Sounds mental, but don't try and correct it, keep it steady and it will sort itself out.
I fail to see how. Atleast if the clutch is in you've got drive helping you to pull you round the corner.
Loos is common with the 306 aswell, personally I just make sure I give it plenty of boot to help pull me round![]()
Yes, which when combined with too much steering correction will cause it to rotate violently in the other direction. You also have the retardation which caused the problem in the first place still there. If you have no forces acting on the front wheels then you're in a pretty safe position.
You are completely wrong, dumping the clutch and removing all power/resistance on the front wheels during a slide will likely result in a spin.
The best option is to bury the throttle, this is widely accepted and proven. You are probably better off doing nothing at all than hitting the clutch.
Oh and what causes that weight transfer?The problem is caused by weight transfer, dipping the clutch is only going to allow whatever slide to continue on it's course.
[TW]Fox;18778257 said:Have to say I am with Mike here. I've always thought the best thing to do is to apply throttle (Though not neccesarily mashing it) to balance the car - it's a balance thing thats causing the problem.
Actually the problem isn't weight transfer, its weight transfer under engine breaking.
Hence the name LIFT OFF OVERSTEER
What occurs when you lift off? Engine breaking.
If you lift off the front wheels attempt to slow the car down, pushing the force (weight) to the front of the the car. This decreases the weight placed on the back which if your turning a corner means oversteer.
If you push the clutch down you remove the engine breaking and therefore prevent LOOS. If you oversteer with the clutch down you're either going way too fast for the corner anyway or you were too late.
I'd mash the throttle personally. I'm also a firm believer that having the clutch down and thus freewheeling for anything other than the half a second when changing gear is a big no no.
