Well i think this one was obvious
http://adamcooperf1.com/2011/03/29/fia-set-to-extend-drs-zone-for-malaysian-gp/
The only reason DRS works (or would work) is because it's only the following driver who can use it. If anyone could use it at any time it would pretty much negate any overtaking advantage it would provide. Similar to KERS. The only reason it had benefit in 2009 was because only half the field had it.
I want to see overtaking because of skill, like the old days ..
Will it make a difference? I thought on long straights, even slip streaming wasn't great because of the rev limiter, won't this just be the same (i.e. by end of straight, both are going as fast as they can)?
This is exactly why DRS shouldnt be put on the long straights. It should be on the short ones.
DRS is really fail for the sport imo
Not because the guy behind (who may be worse, a lot worse, then the guy infront) has a mechanical / aero advantage over the guy in front.
No concern that a better car with an arguably better driver STILL couldnt get past? I would be very concerned if this continued tbhJudging from Button vs. Massa you should have no concerns.
No, I quoted the chap who should have no concerns.
First driver to go through Eau Rouge with it open wins the Steel Balls trophy!
(if I was going to the race that is...)
