iPhone forward text message as email
22 Aug 2005
Clydebank
Hi all
Does anyone know of an app or how I can forward an text message to an email address, other than copy and paste as that is not ideal. And the phone is not jailbroken so no Cydia apps etc
This is pretty basic functionality IMO
Regards.
im sure if you just put the email addy where the number goes it will email it from your phone number instead of an email
EDIT: just done it and it sends it as am mms from your phone number to email addy,
So yes it does work,
press the 123 button in the bottom left of the screen the @ sign is their
EDIT: ignore that reply,. The @ sign is at the bottom middle of the keypad
What i am doing :
Go to messages inbox
Click the arrow
Select a message
Choose forward
Then I get box to enter number
Letters only ,pressing 123 gives me only numbers and a + , no at sign
Can someone else with iPhone 4 verify this please as it is odd.
I have an iPhone4 and both the top two crumplypork look like what I have so I don't know whats up with yours :confused:
Hi all
Regards.
Don't really see the issue you have here, with all the faffing about you could have copied and pasted and emailed it off by now, it pretty much takes no time at all.
It's not really the same thing though. It takes loads of keystrokes, if you want to copy more than one text it's a major pita, there is no attribution or timestamp included in the copied text.
