Iphone 4.3.1 Jailbreak Expected Today!!
Ok I've sorted the issue. Now I have another one :D
Upon prompting me to get the phone into DFU mode, I get to the last step (just holding Home) and the redsn0w program goes to the next stage only for my iPhone to boot up as normal...!
Any ideas?!
which sources should i add to cydia?
are people having trouble downloadin stuff through cydia also? im geting a lot of stuff failed to download when installing things.
Just used AptBackup on mine but from what happened, I'm assuming it doesn't keep the settings for Cydia apps, just what ones you actually had installed before the restore.
i wouldnt use aptbackup some times its screws things up, use pkgbackup, you have to pay for it but its much more better
Springtomise (£1.93) Customise
Winterboard (free) Customise
BossPaper (Free) Customise
MyWi (£19) free tethering
ToneFX (Free)
Bite SMS (Free)
SBSettings (quick access to important switches)
Wifi Sync (paid)
Infinifolders (more than 12 apps per folder)
Cydelete (easily delete cydia apps)
Just to name a few
ToneFX (Free)
Bite SMS (Free)
Wifi Sync (paid)
Just to name a few
What does springtomise help with?
The others I've all heard of before, Ill get downloading now :)
the app i think is most worth investing in for is
Bitesms
It outshines the standard sms app... you can quick compose... quick reply etc check it out...
Another good app is faceclockup.... it speeds up the iphone big time :D
Also multifl0w is a really good multitask app just like on the htc phones..
Sbsettings is good for quick settings.. i.e you just scroll your finger at the top you can switch off wifi... 3g or turn it on etc, rathen then going into settings etc...
Folder enhancer is a pretty app... it expands folders and you can have more then 12 apps inside.
Safari download manager is nice.. you can download zip files from internet (on the phone) etc....
you will need ifile alone there too... which you can browse all the folders on the iphone ( just like windows explorer basically)
Safari tab is again a nice way of scrolling through different web pages..
Barrel is nice... you can animate the way you scroll through pages..
Graviboard is a nice app for you to show off to your friends...
Winterboard is a must to install themes
CYDIA is your best friend.. go through each app when you have time.. it will give you a description before you download it... definatly worth checking out
