4 Apr 2011 at 23:31 #1 MOOGLEYS MOOGLEYS Soldato Joined 24 Dec 2004 Posts 19,375 Location Telford Quick question as above will a 790x mainboard with 8x 8x crossfire be enough for a pair of 5850's.... Cheers
4 Apr 2011 at 23:34 #2 BlackBat BlackBat Associate Joined 5 Jan 2008 Posts 654 Location Stoke-on-Trent AFAIK 2x8 gives 95% of performance of 2x16.
4 Apr 2011 at 23:36 #3 Pighardia Pighardia Soldato Joined 9 Jan 2011 Posts 17,987 it will work fine. I'm running my 5850's in a x8/x8 set up (i don't even need to crossfire, but they were so cheap) I imagine you did the same
4 Apr 2011 at 23:40 #4 MOOGLEYS MOOGLEYS Soldato OP Joined 24 Dec 2004 Posts 19,375 Location Telford Exellent, I have no need but I have been offered so cheap resistance is futile... Now I hope my TX650 will power it all, I have faith in the high current beasty... The board is an ASUS M4A79XTD EVO seems a good ish board. Last edited: 4 Apr 2011
5 Apr 2011 at 13:58 #5 Cookeh Cookeh Soldato Joined 21 Jan 2010 Posts 8,442 Location Ceredigion BlackBat said: AFAIK 2x8 gives 98-99% of performance of 2x16. Click to expand... Fixed 95% is for 16x/4x. 790FX chipset will be perfectly fine for CF/SLI with any card
5 Apr 2011 at 13:59 #6 MOOGLEYS MOOGLEYS Soldato OP Joined 24 Dec 2004 Posts 19,375 Location Telford Still waiting to get the go ahead on this.. Will update when I find out if I can have the bits....
5 Apr 2011 at 14:05 #7 Cookeh Cookeh Soldato Joined 21 Jan 2010 Posts 8,442 Location Ceredigion Just to clarify, a TX650W should be perfectly adequte for your low voltage Phenom and 2HD5850s The two HD5850s should use about 380W in Crysis (according to anandtech - seems a bit high to me though ) and your CPU probs draws about 140W
5 Apr 2011 at 14:06 #8 Muel Muel Soldato Joined 26 Jun 2009 Posts 3,023 Location Sheffield Cookeh said: 790FX chipset will be perfectly fine for CF/SLI with any card Click to expand... Pretty sure it only supports CF? I'm running 5830 CF on x8/x8, but never run it x16/x16 so I've got nothing to compare it to.
5 Apr 2011 at 14:08 #9 Cookeh Cookeh Soldato Joined 21 Jan 2010 Posts 8,442 Location Ceredigion Sorry, you are ofc correct. I'm talking out my arse for once.
5 Apr 2011 at 14:09 #10 MOOGLEYS MOOGLEYS Soldato OP Joined 24 Dec 2004 Posts 19,375 Location Telford Cheers chaps.... Hopefully this board will run my 955 @ 4ghz as my MSi micro does.
5 Apr 2011 at 14:09 #11 Muel Muel Soldato Joined 26 Jun 2009 Posts 3,023 Location Sheffield Yay! I called someone and got it right for once.
5 Apr 2011 at 14:10 #12 Cookeh Cookeh Soldato Joined 21 Jan 2010 Posts 8,442 Location Ceredigion Muel said: Yay! I called someone and got it right for once. Click to expand... So used to saying CF/SLI because EVERYONE is asking for SB specs in GH /excuse
