- 30 Dec 2003
- Bigger box!
Yep, that's what I said. The inference will be a negative one.
They will know your name anyway before the interview. They can ask you for your name in the interview and if you answer that, but then stay silence to other questions, a negtative influence can be drawn.
And yes, giving your name in an interviewing and then remaining silent or answering no comment can be viewed negatively in court, because I was taught this by a ex-high court judge (who's husband is in charge of a police station) that this is not an uncommon police tactic and she has had to direct the jury on this issue before.
So yeah... not made up![]()
You said that 'it allows the court to infer that you're deceiving the police'. Tosh. Stating your name then remaining silent or going no comment does not imply deception at all. Whether you state your name or not, the inference as to why you do not give an account when given the opportunity to do so is purely in relation to the questions asked of you about the matter you have been arrested for. To answer your name but then go no comment is not worse than simply remaining silent.
To answer some questions and not others may come across worse, but answering to your name is just something to identify that it's you being interviewed on an audio tape.
What's not an uncommon police tactic? The choice to go no comment is made between the brief and client.
If you go no comment the police can, in relation to certain things, give you a 'special warning', which states very clearly to you and for the tape, that your choice to remain silent or go no comment will result in the judge, jury etc drawing a 'proper inference' as to why you have chosen not to give an account when given an opportunity to do so. That's not a 'tactic' that's to make sure you fully understand the effect your 'no comment' may have on your trial, should there be one.
What's with the wink? Not sure I understand the context? Hope it wasn't to emphasise that you are better informed, because that would just be embarrassing for you!
