- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Thermalright Shaman Graphics Card Cooler (GTX 460 / 470 / 480 / 5870 / 5850 / 4870 / 4850) @ £49.99 inc VAT
World’s First VGA cooler that supports the compatibility with 14cm fan with the dissipating area of 140mm * 130mm. World’s First VGA cooler with 8 * 6mm heatpipes, easily cools the hottest VGA in the Market. All new installation methods, provides easy mounting and gives better overall compatibility. Supports both 12cm or 14cm fan. Includes one Thermalright TY-140 PWM fan, Ultra low noise at 21 dBA at max rpm (50cm testing distance). Multiple support back-plate, to provide the best protection for your GPU. Mirrored Copper base, with quality craftsmanship.
- Supports GTX460/GTX470/GTX480/HD5870/5850/4870/4850
Heatsink Specifications:
- Dimension: Length 160mm x Width 132mm x Height 38mm
- Weight: 500g (Excluding fan and Mounting brackets)
- Heatpipe: 6mm heatpipe*8 units
- Copper Base: C1100 Pure copper nickel plated with mirror shine
Fan Specifications:
- Dimention: Length 160mm x Height 140mm x Width 26.5mm
- Weight : 140g
- Fan speed: 900~1300RPM (PWM)
- Noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Connector)
Only £49.99 inc VAT.
ORDER NOW
Fan Specifications:
- Weight : 140g
- Noise: 19~21dBA
- Airflow: 56~73CFM
ORDER NOW
