are you crazy? both play run fine on this card![]()
You probably wouldn't call me crazy when I kill you in multiple player games while you play at 30 fps.
I've just upgared my grapics card from a 4850 to a 5850 which most people would consider a mid-range card.
I've only tested afew games with it. FarCry2 on make it doesn't drop below 80FPS and Battlefield BC2 also on max doesn't drop below 50fps.
Are there any games out there that this card will stuggle with this card, considering monitor refresh rate is 60hz.
My point is if the £120 5850 will handel everything thats out there at the mo at this speed, whats the point in paying £250+ for a top end card.
People also have a wide difference in incomes so you can have one man on minimum wage the difference between a £200 and a £600 card is a big deal but to someone who earns £1000 a week the cost difference between the cards makes little difference to them.
What if you earn £1000 a day or higher then £600 is pocket change to those guys.
Ive worked hard all my life and now retired and the kids have long since grown and fled the nest so when i wanted a 6990 and EK water block its a nice toy to play with that gives me pleasure and i can afford it so why not.Life's too short so if you can fill it with nice toys while it lasts do it.
+2People also have a wide difference in incomes so you can have one man on minimum wage the difference between a £200 and a £600 card is a big deal but to someone who earns £1000 a week the cost difference between the cards makes little difference to them.
What's the point with multi-GPU setups?
i simply don't understand those epeen people, especially when new games doesn't work. (eg. Crysis 2, AC:Brotherhood)
They said same when i had gtx 8800s in sli which ive long since given away because it was too slow to run bugger all.Three quotes.
I'm surprised you're not getting hammered with "overkill" comments. That seems to be the trend around here when somebody has a beastly heatsink/fan or a high end graphics card or just something genuinely expensive. I'm so sick of that term to be honest.
