Depends what sort of use it's going to get, but for light use and to tick the box i'd love an E-type to run around in, then when you've finished driving it you can sit back and admire it.
*total outside the box idea i know.
I was thinking that what about a 6 series though?
Before anyone suggests it i dont want a 996 bottom of the barrel.
Cant drive it every day, no air con, be honest they are ropey to drive.
The usage, well when its sunny il drive it with the roof off.
I've no idea if they are any good or in budget but what about a convertible Jag XK?
[TW]Fox;18865537 said:£20k gets you the old model. Not a bad car, but it came out in 1996 and is totally ancient. You can get fundamentally the same thing for £5k.
If you have no idea if they are either any good or in budget I do wonder why you feel in a position to suggest one, mind. He is asking for a recommendation, not us to shout out random car names.
[TW]Fox;18865549 said:Buy an SL, Seriously.
It does everything. It is supremely well made. It wafts perfectly with it's brilliant autobox and fanastic V8 engine. It looks like its worth much more than it costs, it has a timeless design, it's the definitive convertible GT car.
Take it you wouldnt want another Maserati?
If so 4200 Spyder, engine would sound simply epic with no roof.
Was just a thought, and odd for him to not mention it considering he's had 2 (Coupe's) so obviously likes them and isn't bothered by the age and may prefer something like that if it's only for 6 months.
Silly running costs, most of them engine related i take it?
