The new Orange Android phone (San Francisco) £99...but a Question??
It will be 2.1. There isn't an official 2.2 rom, but the custom ones made on Modaco and such are pretty much as official as you are going to get. They are 100% stable now, and with CM7 final coming out soon, there should be a pretty much fully stable 2.3.3 build!
doesnt the newer SF released through the EU have 2.2 standard? :)
When I had SS RLS4b installed I found that the "dialer" was keeping the phone awake for many hours.
Same problem with RLS4b, Partial wake absolutely killing my battery over night.
That's CM7 final core, not the blade specific part, isn't it?
Gem Miner keeps crashing for me and I'm addicted to it! Do you think it could be because of the ROM or the device its self?
Plays fine for me using SS RLS4b, even if I do keep getting buried underground.!
The only issue I have with SS is the battery drain but I'm giving it a go again due to the GPS issues with CM7.
GPS reboot issues fixed with CM7 N38 just released. Been running it this morning, and so far, working great!
Hey, So what is the easiest method of backing up apps and settings so that I can restore them after putting on CM7 N38?
Could some one suggest a San Francisco case for me that isn't from Ebay? I hate using ebay and don't have it setup. I did have a look on Amazon but most of them seemed to be cheap ones that looked quite flimsy.
Cheers
