Caporegime
- 18 Oct 2002
http://www.anandtech.com/show/3621/amds-radeon-hd-5870-eyefinity-6-edition-reviewed/6
Biggest gap is Crysis minimums, 15fps vs 8fps, neither are particularly playable, basically they've run out of gpu power before memory became an issue, even then the average is indistinguishable, what does that mean, has it run out for the entire benchmark, no, it almost certainly indicates for 1-2 seconds it came borderline but for the rest they were evenly matched. The drop to 15fps from 30fps average would be as clear a drop as the one to 9fps, both would be visually obvious and for the rest of the benchmark you'd also be able to tell no difference.
Battlefield, marginal difference, but at that point the cards themselves are unable to provide high enough average for you to play anyway.
http://www.anandtech.com/show/3621/amds-radeon-hd-5870-eyefinity-6-edition-reviewed/7
No real difference, horrible performance in some situations anyway.
http://www.anandtech.com/show/3621/amds-radeon-hd-5870-eyefinity-6-edition-reviewed/8
Would have been great if they showed the 1gb card versions in with that set as you would almost certainly see max performance vs 1fps on the 1gb versions. But shows, look at some of these numbers, 6x 1920x1080 screens, on a 2gb card, some with 4xaa, no memory limits.
ANyway, what that shows is, at 2560x1600 max quality, 4 or 8xaa, incredibly marginal effect of memory, and where it happens, it offers no playable difference to a 2gb card.
Again I'll point out, CONFIRM YOUR READINGS, go e-mail Nvidia and ask them what gpu-z is reading, ask a reviewer to ask, a reviewer might know, drop anandtech an e-mail.
Or most importantly, show the difference in performance, with the same settings, where a 1gb card is unplayable and a 2gb card offers a completely different performance. No, one frame in a benchmark does not constitute that, not even close.
