Poll: ****Official Battlefield Bad Company 2 Thread*****
Which type of game play would you prefer
  • Normal Rush Mode
    Votes: 481 33.4%
  • Hardcore Rush Mode
    Votes: 222 15.4%
  • Normal Conquest
    Votes: 507 35.2%
  • Hardcore Conquest
    Votes: 229 15.9%
  • Total voters
    1,439
Are you using very old drivers? It used to be an issue many many driver versions ago.
Personally since the fixed drivers I tend to load super quickly - this is across 4870, 4870x2, 5870 and 6970 cards.
no its the latest 11.3 ive just put on as i remember when it came out it use to do it till they sorted there drivers,might do a fresh install and see if that helps cheers
that's just typical.... what if i want to play forward VSS recon?
the "CustomPC" (search term) server also runs weapon limiter, but it only limits 12x scope. most bush wookies use 12x scope, and the CPC server only limit that, so if you wish to use VSS or quickscope on the front-line, it is not discouraged.
/shameless plug
This is encouraging, I will favourite this server tonight then :P
Only just recently got into some short / medium range sniping, it really ****es me off when I can't play as recon because of those disgusting class limits...
