- 6 Jul 2006
- co durham
Are you using very old drivers? It used to be an issue many many driver versions ago.
Personally since the fixed drivers I tend to load super quickly - this is across 4870, 4870x2, 5870 and 6970 cards.
no its the latest 11.3 ive just put on as i remember when it came out it use to do it till they sorted there drivers,might do a fresh install and see if that helps cheers
