depends on the pcie bus.
if its 16x/8x/4x or 8x/8x/4x then maybe no
He has a ud7, 3x6970 on x16x8x8 will still be faster than 6990+6970 on x16x16
only by afew fps..He has a ud7, 3x6970 on x16x8x8 will still be faster than 6990+6970 on x16x16
Personally, I always find hardocp's reviews are a bit...pointless for majority of the people, since 95% of the PC gamers game at 1920 res or below, and they always bench at 2560 res or triple monitors set-up.Hardocp done an article on trifire today
http://hardocp.com/article/2011/04/11/amd_radeon_69906970_crossfirex_trifire_review
my system with the 6990 + 6950 unlocked draws about 675w~ under load.
6990 set to default bios but clocked to 880/1250..... it can clock to 950mhz on stock voltage.
as i said 6990 + 6950/70 runs really well if setup right but can be a pain to get setup,650W isn't bad. I have a 1250W PSU. Is it worth it mate? Honestly? Or would have gone 3 x 6970s?
getting another 6970 would be cheaper, but would give a lot more heat and maybe louder.
i've got the 6990 because it was a gift from amd..
well if you ahve the money get two 6990s and be done with it![]()
Plus depends what games you play etc. plus helps with profiles.
plus there doing a deal on the HIS ATI Radeon HD 6990 http://www.overclockers.co.uk/showproduct.php?prodid=GX-033-HS
no mate. it's running at 16x/16xHey Gareth, IS your 6990 + 6970 running at 8x8x? I was wondering if the x8 lane would bottleneck the 6990 by much? Or can anyone else help me on this?
Cheers.
make sure u disable UlpsI see. Are there guides to setting them up right?
Go to registry :
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\ class \{4D36E968-E325-11CE-BFC1-08002BE10318}]
and change "EnableUlps" to 0 under the 0000 and 0001 and 0003 keys.
http://forums.overclockers.co.uk/showthread.php?t=18236540Plus, who did you have to kill to get that 6990?![]()
I've heard they suck at the moment mate, due to poor drivers. Typical AMD really
