Iphone 4.3.1 Jailbreak Expected Today!!
Thinking about JB'ing again to 4.3.1 today. Has anyone used PkgBackup to restore all their JB'd apps etc after jumping to an updated iOS?.
Does anyone know if it's possible to easily backup all Winterboard and Lockinfo settings / customisations?. Does PkgBackup do this as well?.
Ta.
Ive heard good things about it...i used aptbackup and that royally messed up my apps ie they didnt restore as they were meant to...good thing i have a list of my jb apps in a file on my laptop so was able to get them back.
I dont think its possible to backup your settings etc as i asked this question a few days ago and was told that there currently isnt any way to do so...shame because an app like that would go a long way.
Unless there is a way of somehow backing up your settings...
EDIT: im about to buy it, its $8 but it does say on the description that it backsup your jb apps and preferences and springboard files...
Those using fakeclockup...really need to use springtomize instead imo. Has the fakeclockup tweak and loads of others. Saves installing multiple tweaks.
Ok far enough, just make sure you try out iRetina with sbsettings :cool:
iRetina is a nice improvement over the default icons, thanks. I do find SBSettings doesn't really work properly in landscape mode which is a bit of a shame, but even so it's really handy for turning bluetooth on and off quickly. :)
got a new iPhone today - I restored it before I took it back just in case, but they didnt even check, just got a straight swap :)
