Input Signal Out of Range
29 Dec 2009
Beijing
Hi all,
I have a slight problem when I boot my PC up I sometime get Input Signal Out of Range on my monitor when it is loading the BIOS and Windows. I only get to see stuff on the screen when it has loaded the operating system.
Some times it will boot up fine and I can see the BIOS and the OS load but other times it doesn't.
I have an Asus P7P55D-E motherboard and an ATI HD 6870 graphics card.
Any ideas what this could be?
Check to see that the VGA/DVI/HMDI which ever connection you are using is connected firmly and securely.
If they are it could just be a duff cable, if u have any spare give them a try.
I saw this recently. It was a known working crt monitor which was being connected. for the first time, to a Win 7 installation. Presumably the refresh or resolution was no good for the old monitor. I couldn't tinker with the pc as it wasn't mine to tinker with. Would booting in safe mode offer any insight?
It's an I-INC AG191D monitor. Worked fine on my old PC.
Is there an autodetect option in the monitor menu? Might be worth trying that when you see the out of range signal. If it works then, maybe you could enter the autodetect settings as default.
Why is it? Works on all my other PCs running Windows 7 just not this one.
Yeh it does I'll give it a try next time it does it.
