Dzeko is a heading goal machine.
Pique
How do you get these?
RONALDO
Aguero would be nice though
But ronaldo would mean limiting my team in other areas, Aguero would open that up.I knowwwBut ronaldo would mean limiting my team in other areas, Aguero would open that up.
Need 3 x CM's, CF and 2 x ST for 1.2mil.
Is Aguero that much? I wouldn't bother. IF Benzema! Get the cheaper IF Ozil too...the cheaper one is under 100k, the one up 200k
the problem's i have had with EPL are no decent CB's for less than 100K (you really need IF Kompany and IF Onohua) all the others are too easy to get past. No decent keepers either, ive had van der sar and reina, and tbh van der sar felt better. IF Cech is supposed to be great but he is too expensive for a keeper.
its hernandez for me.
isn't he also 4ft tall? Your playing some bad sides if he's out heading dc's!
Not really renowned for his headingisn't he also 4ft tall? Your playing some bad sides if he's out heading dc's!
I presumed your speaking about the man u guy as you support man u, but his name isn't slept with a z so I guess you could be speaking about Abel Hernandez?? Put me out of my misery![]()
hes a good jumper.Fancy a game?Snip
Molinaro as LB (only 1 better is IF Pranjic but i cannot justify spending 75K+ on a LB)
so its 2 super power house teams vs 5 super teams (might drop this down to 4 after i figure out which of the 5 is weakest, most likely going to be Ligue 1 or EPL)
