it's really 3GB. 2x 3GBregardless of its validity.. 6 Gb of VRAM is overkill
Haven't we seen this before? Pretty much proven to be fake, especially given the 'Steam processors'.
While it doesn't seem that likely this soon, its certainly possible.
Also remember, the steam processors have 64 per cluster, 64 into 6400 most certainly works, infact, it should be more than obvious
Why wasn't the 6970 1600 sp's, very simple, it would have been 25 "clusters" of shaders, while chip design certainly doesn't have to be symmetrical life is generally just "easier" when it is.
When you double up the shaders on a new gen, 25x2 = 50, or, a nice round number a symmetrical core can easily be made up of. So yes 3200 shaders per core and 6400 total in a dual gpu card is VERY possible.
But will the 7990 be the first card they make, that soon, who knows.
I wouldn't be surprised if the next real big gen step doubled up shaders(or came close).
Though if they manage to get some of the front end efficiency from the 6870/50 added to the new shader architecture of the 6970, they might not need to hit double the shaders to come close to doubling the performance, something closer to double a 6870 could be all thats required in terms of shader count.
Of course, if they have the 28nm part working fine, or if they are only making the high end cores at TSMC and therefore only then that would be the only thing they would tape out there.
I'd assume the specs are guessed/fake, but that doesn't mean that aren't a close guess.
bump in base clock, considering its going from 40 to 28nm, and a BAD 40nm, really shouldn't be surprising.
what is the advantage of a 28 nm die
He probably put together the most expensive thing he could find and put it in his sig![]()
OMG
thats some spec you got there mate?
how do you find it?
