but you're half a million XP points ahead! :O
Thats the beauty of playing in a squad with dedicated classes i play as engineer and tach when needed.
Ah, I'm used to playing alone so I don't bother with the objectives.
Yeah sure seems like a idea if we cannot control all the spawns on the map .operations to me still seems to run better but i do enjoy warzone when most regulars are on and were using comms for planning .yes its nice to have both spawns but its not essential, if you cant get 1 then you can camp it to stop them spawning there whilst the rest of the team can do the objectives.
Why were you unable to capture a spawn point with 7 people? Did they have lots of tacticians?
No not a lot of tachs a lot of marksmen with assault rifles and infiltrators it was on mwlar graveyard they used the crusher to good effect and backed up with medics .
Wahts truly annoying is when u chuck a nade thru a door or window, the trajectory is fine , looks like its going to go thru then all of a sudden it hits the side or the top of the door and bounces back
but only if they get it running smoothly.
How about this one then - I was playing as a medic and threw the mortar target thingy. It bounced off my medibot and landed right on top of me. Hence I got blown to pieces.![]()
Whats your Psn id bud i can send you a invite so i can invite you to chat text and into mp games
What happened to ic1male i still see you log in on that stilli have sent roguetracer a request though
Not seen that error before but then i only seen the common one 20002 or whatever it was that happened more before patch 1.7 .
I hope you can get on over the weekend din really starting to like operations now![]()
PSN = Jaybebabeh
The gf thought of it lol![]()
will add you soon as psn is back up budyeah i played the sp with move and 3d and it rocked did go back to pad to do it on elite though . hopefully this 1.8 patch sorted a few issues just i have not manage to try yet.
