Folder keeps reverting to "read only"
2 Jun 2004
A program I use is giving me error messages when trying to save files. The only thing I can think of being the cause is the folder its trying to save to seems to be "read only".
But when I right-click and change the properties, if I go back and check, it's set back to read-only.
I'm the only user, on this PC so I should have admin privelages, so I don't understand why it always instantly reverts to read-only. :confused:
Any ideas?
XP folder Security tab is usually hidden by default or if not NTFS. Look under Tools > Folder Options > View (Tab) and at the very bottom of the Advanced Settings list - untick the "Use simple file sharing (Recommended)". The Security Tab should then appear.
