Hi,
To cut a long story short, I am currently running a HX850 PSU and 3 GTX 570's, do not ask how this came to be lol. To get the system to run without crashes I have had to underclock my GPU's from 786mhz to 550mhz
Now my question is, which PSU would be better suited to the job? A Performance/Price ratio applies here. I have had a wattage meter on the plug that is powering the PC and with a second 500w PSU to run the 3rd card, running the cards at stock and the CPU at 4.6ghz the system was drawing around 900w altogether.#
The system is currently rock solid with GPU's under clocked and the CPU at stock but of course I want them back to normal lol.
HX1000:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-012-CS&groupid=701&catid=123&subcat=1084
AX1200:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-029-CS
I am open to alternative suggestions but the PSU would need to look good in my FT02 with the hardware that is in my sig as it is clearly visible.
Thanks.
HX1000:
AX1200:
Thanks.
