Fancy testing some Alpenföhn fans? Post in this thread!
Interested. I run a rig here in Singapore which has a unique range of temp from 32C 100% humidity to 20C aircon. Makes for some interesting test combinations. =)
Would love to be able to test 2 x 140mm and 1 x 120mm.
Basically I want to test how much better they are than the stock fans in my Coolermaster CM-690 II Advanced Dominator Case.
Great case, but I feel that the fans are a bit noisy. Would be interesting to see any temp changes in my CPU, GPU etc.
i have the same case and would love to test this too if possible :D
Hi. I am happy to test them on my 360 rad if you wish and can compare them with Apache Blacks and S-Flex fans for temps and user perceived noise.
Matt
Yes please :) a couple of 120's would be fanstatic, im colour theming my build black and blue so these are perfect :D will be testing them on a black ice rad cooling a 1055t, and comparing to akasa vipers and air cooling using the noctua DH-14
I'm definatly up for testing two 120mm's to sandwich my Ultra 120 eXtreme between :)
I've got a 140 as a front intake in the 5.25" bays but it's not essential
Hi if i am not too late I would love to test these fans please. I have a NH-D14 so either or both fans would be great, also my case has 120mm & 140mm fans that I could swap out for testing. Thanks
Michelle
I believe in don't ask don't get and have just had an idea. My CPU is cooled by a Thermolab Baram and what is often called one of the best fans out there, the Noctua NF-P12.
I could replace all my stock case fans and the Noctua on my CPU for a full Alpenfohn fan setup. That way I can measure any temp drops properly, as measuring drops against changing case fans only is a little misleading as I am unsure it would make much difference.
Hi
I use an H70 to cool my i7 950 with 2 x Akasa Vipers installed would be good to see how they compare.
Thanks
Chris
I've just bought a H50-1 for my i5 2500K @ 4.5GHz so count me interested!
If I am successful then expect pictures of win magnitude :D
Hmmm probably too late but I'm interested, I'm using 9 Arctic Cooling F12's and 3 NZXT 140mm 9 Blade to cool my two water loops at the moment, for more details see my sig. Happy to try either a few 140's or a few 120s in places to see the difference.
OC'ed i7 950 rampage II extreme + SLI MSI Frozr II 470s
Some beauties in that list! but tell me there isn't an awesome looking gpu cooler called "Peter"?? LOL
Also, why do none custom coolers I've looked at ever list the 4770 in the fitting list?? :(
