Looking to Purchase a 6950 in the next few days/next week,
Just wondering which rev.1 has the lowest noise levels?
Any help is appreciated![]()
Apparently the Sapphire 6950 2GB has and it's the one I bought
It also depends on your idea of 'quiet'.
I am using MSI Afterburner for OC and fan control. I have a Noctua NH-D14 (both fans on) and two Sharkoons Silent Eagle 1000. Loudest fans are the Sharkoons at idle.
snip
My Sapphire 6950 fans don't go above 60%. From 70°C+, it drops down to the 40s °C in under a minute.
I know people who don't set their fans above 50%.
The Sapphire is pretty damn quiet for a high end graphics card. Even when overclocked.
Noise is of course subjective. I went for the Asus for no particular reason. Noise under load wasn't bad, in fact it was less than my previous Vapor-x 4890, but noise under idle was just unnaceptable against the relative quiet of my idle rig where the fastest fan is about 700rpm.
I'd always intended fitting an aftermarket cooler eventually but after living with the idle noise for a fortnight I changed the cooler and it's now perfect.
Your mileage may vary of course and you may find it perfectly acceptable.
I would have thought one reference will be the same as the next, or at least mechanically anyway. Different vendors may have slightly different fan profiles.
GPU fan noise to my ears.
24% fans inaudible. 29°C - 39°C (IDLE)
30% fans practically inaudible. 40°C - 45°C (Warming Up/Movies)
35% fans just audible alongside Sharkoons. 45°C - 50°C
40% fans audible hum above Sharkoons. 50°C - 60°C (Gaming start)
45% fans audible hum above Sharkoons. 60°C - 65°C
50% fans are a moderate-loud hum above Sharkoons 65°C - 70°C (Long term gaming)
60% fans are a loud hum above Sharkoons 70°C - 73°C (Peak benchmark temps)
80% fans are very loud/almost roaring (unused)
90% fans are roaring (unused)
100% fans are almost deafening (unused)
my his is pretty damn silent even with 6970 flash. I don't notice the noise it makes when I game, but I always game with my steelseries siberia's on so make w.e you want of it...
As for which one to buy? Buy a regular one that is the cheapest. I wouldn't worry too much about warranty length as electronics (in my experience) are usually DOA than die over time.
I have a 6950 2gb with the stock cooler.
The bios flash didn't make the fan noise any noticeably louder (I would assume it was a marginal increase). However upping the voltage to that of the 6970 does add fan noise.
It certainly isn't bad at all, far from it in fact. Just be aware than cranking up the voltage will up the noise. Adding a custom fan profile will solve that though as the stock fan profiles will be hugely on the safe side.
I am running my card at a touch under the 6970 voltage with all the shaders unlocked and core at 900mhz. The fan is a little noisier than stock when gaming - but then you have your speakers or headset on. It is silent when not gaming.
A fair few gpu's ago I had an x1800xt......and trust me.......modern gpu coolers don't sound like a vacuum cleaner like they used to!]
