The new Orange Android phone (San Francisco) £99...but a Question??
From what I have read that GPS issue seems to be related to Google Maps, which I do not use. My GPS application, the little I have used it, runs fine.
It was Fancy Widget Pro causing the constant reboots. Going to change to beautiful widgets and hopefully that app wont have the same issue.
Cheers
Cheers
Got BW yesterday, everything is fine, i was sceptical about paying for an app, but for less than £2, you cant go wrong i dont think :)
So GEN2 is meant to upgrade your Upload speed, well I wasnt finding that:
GEN1
GEN2
But I've had the same T-Mobile SIM card for 6 years so I got a newer SIM:
:D
Right I had CM7 rc4 on the wifes phone and she stopped complaining that it was crashing/ freezing etc then for some reason i installed 7.0.0 shes been having nothing but bother with it locking up etc, only way around is to remove battery and reboot. Before I go back to RC4 are there any other suggestions of roms to try? Still GEN1, not sure if its worth updating to gen2 yet?
Go back to RC4.
I was in the same boat. I used RC4 since release (skipped the nightlies up to stable) and then installed the "stable" release. Had nothing but problems, with freezes, lags and crashes. Went back to RC4 and it's great.
Go back to RC4.
Right, i just put sweedish thingy ma bob on :) seems ok so far, will let her try it for a day or so and all fails put rc4 bag on
When I used SS 4 I found that I had some issues with the Dialer causing the phone to be awake for a long time, shown under spare parts / partial wake usage. However my wife's SF did not show that, with the same apps installed.
My wife's phone is a B10 and mine a B08, not sure if that matters.
When using CM7 I do not get that issue.
I was on JJ9 until about a fortnight ago. I went to SS RLS4 and whilst I had a litle hiccup at the start (I can't even remember what it was now!), I installed ADW Launcher and I'm very happy with it :)
i see.. well ill wait for a bit then..
got the case today..
some pics if anyone is interested
Anyone know of any good deals on these at the moment? I'm after another one but would like to only spend £80/£90.
The Modaco forum has a ton of stickies on sellers so that might be worth a look, I'm a bit wary of getting a new one with all the gen2/b8/b10 issues and random stuff since I got my original gen1 last year.
http://android.modaco.com/category/453/zte-blade-blade-modaco-com/
There are people on there though who know which store has what kind of stock and any deals etc though :)
/off to try SS Rls5
Well, I've had fun modding my San Fran, but a HTC HD2 running Andeoid 2.3 (and hopefully dual booting with WP7 soon too!) has just arrived, a new toy to mod! :D
