It was Fancy Widget Pro causing the constant reboots. Going to change to beautiful widgets and hopefully that app wont have the same issue.
Cheers
is there a mod that allows unlocking with menu/home/back keys?
Yes, but it will kill your battery since it prevents your phone from entering sleep mode.
http://www.appbrain.com/app/softlocker-free/otis8.softlocker
Other than that, no.
Right I had CM7 rc4 on the wifes phone and she stopped complaining that it was crashing/ freezing etc then for some reason i installed 7.0.0 shes been having nothing but bother with it locking up etc, only way around is to remove battery and reboot. Before I go back to RC4 are there any other suggestions of roms to try? Still GEN1, not sure if its worth updating to gen2 yet?
Go back to RC4.
I was in the same boat. I used RC4 since release (skipped the nightlies up to stable) and then installed the "stable" release. Had nothing but problems, with freezes, lags and crashes. Went back to RC4 and it's great.
I was on JJ9 until about a fortnight ago. I went to SS RLS4 and whilst I had a litle hiccup at the start (I can't even remember what it was now!), I installed ADW Launcher and I'm very happy with itWorth moving from Jelly fish to Swedish Spring yet? is it stable?
I was on JJ9 until about a fortnight ago. I went to SS RLS4 and whilst I had a litle hiccup at the start (I can't even remember what it was now!), I installed ADW Launcher and I'm very happy with it![]()
Swedish spring sometimes needs a reboot for data to work for me![]()
Anyone know of any good deals on these at the moment? I'm after another one but would like to only spend £80/£90.
