- 21 Apr 2011
why would WD confirm the issue and release the bios utility to edit the settings if it wasnt true?
I don't see where he claims that the load cycling issue *only* appears on RAID configs, as you stated above...?
I don't see where he claims that the load cycling issue *only* appears on RAID configs, as you stated above...?![]()
Nope. WD Black for my OS, apps and games, and Green for storage. Windows 7 x64 Ultimate.
Apprently when it reaches 300,000 cycles it will fail
Daniel Mauerhofer, Head of EMEA PR in Western Digital has commented on this article. "This issue is far from critical, does not impair normal functionality or place data at risk, can be mitigated with a utility for the small percentage of systems affected, and is a well understood industry standard."
I ran the tool as suggested and it seemed to work but the verification step ("wdidle3 /R") didn't work (I got Abort/Retry/Ignore after a few minutes of nothing) so I don't actually know if it worked or not.
