About to order, last check.
Caporegime
8 Nov 2008
Hi,
I am near the point of ordering some goods, if anyone can think of something I have not thought of / compatibility then please add any comments.
Relevant spec listed :
Q6600 @ 3.4
Gigabyte X48T-DQ6
Enermax Galaxy 1kw psu
About to order :
I'm still not wondering whether to get a Hybrid or not, and I also have been thinking about the 2gb 560 / SOC 1gb 560 / 570's. It's very different when it's your own decision, the agony of choice! :)
I just noticed that my motherboard has the SATA 3gb/s connectors, not the 6gb/s that some SSD's list. I obviously assume that, like with SATA3, you are restricted to the choice with a third gen mobo like mine?
SATA 3 (6Gb/s) is backwards compatible with SATA 2 (3Gb/s) so a SATA 3 drive will work in a SATA 2 port.
So, just to clarify, I am not restricted in my selection? For example, I can choose a SATA 2 SSD which has a 6gb/s connector on my 3gb/s SATA 2 mobo?
I just need to be sure before ordering, would hate to make any basic errors. :)
There's no such thing as SATA 2 with a 6Gb/s connector.
SATA 2 is 3Gb/s.
SATA 3 is 6Gb/s.
You can buy a SATA 3, 6Gb/s SSD and it will work in your SATA 2 ports.
