^^ is it worth less than a coffee ?
If you are having trouble getting motivated to get the last bits of experience points to reach level 50, it adds a few challenges to help you in that.
i stayed up til 4am playing ME1 btw
it completely sucked me in!
Just bought Sims 3 night life, fast lane and outdoor stuff plus Crysis 2 for £29 - not bad at all!!!
How is the Sims 3? Should I buy it or will I get bored after a day?
(thanks to whoever posted the £10 off code too).
Bought Shift 2 and Dead Space 2 for £25, not bad at all.
Does the EA Download Manager download the latest version of the game or will I have to patch them up? Also does it patch games for me when they are released?
Cheers.
I caved and bought Crysis 2 for £12.50.
Managed to get it for £8.32 so I'm pleased considering I had it on pre order for £25. Very impressed with it so far. I was expecting it to be rubbish.
To get it for £12.50 you either used a £5 voucher or bout 2 £17.50 games then used the £10 voucher. For £8.32 the total before £10 code would be £26.64 my 10% off for closing basket doesn't work with the £10 voucher maybe Asgards did. Thats how I'd see it if I got 2 games the same for each because its easier than dividing by %.
Crysis 2 is £17.49 atm.
You can get £10 off if you use the promotion code when spending over £25.
You can use Cokezone points to get a £5 or a £10 voucher when you spend over £15 or £25 accordingly.
You can get 10% off the final price by quitting the basket.
So (£17.49-£5)*0.9= doesn't add up
But for £11.24 it's a good price
I guess he paid for something else too.
The thing is the most it'll give me off the basket is £10 and then it refuses to give me 10% off on top.
