msi HD6950 core stucked @ 500mhz,any help please?
well...
put thermal paste= nothing change...
you u know if when you change the ventilation system you have lost the warranty??since i bought the graphic card 25 days ago...
any other suggestion??is there any software that i could use to force the graphic card to use the 3d profile??because it does not charge it at all, neither the 1.10v for it....and i restored in bios 1 the back up bios also...
well...
if you've removed the cooler then you've lost the warranty
try going in safe mode then see if it drops
Just to check you have put the vrm heatsinks in the right place and that you didn't miss adding a heatsink to the left of the top bank of memory chips(the one in the circle):
Have you ran any games while logging your cards performance through Gpu-z?
The clocks won't increase until you are playing in-game, check your clocks with Gpu-z preferably during a level not on the options menu.
You can get Gpu-z at techpowerup.com:
http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
Yes, i have put all those heatsink,also the one with the circle...
i have also tried the gpuz when playing:
core clock 500mhz
memories 1250mhz(if i overclock to 1400Mhz) they will run at 1400,it is only the core clock which is stucked maximum at 500mhz instead of 800 or whatever i choose in ccc or ab...also the voltaje keeps at 1.00v instead of 1.10v when playing to start the 3dprofile.
no idea what else to do...:(
gareth tried the safe mode but it did not let me open neither gpuz or any game...(i think because graphic drivers were not loaded...)
¿?¿?:confused:¿?¿?
it should let u open MSI AB...
or in normal mode, uninstall the drivers then run msi AB to see if it clocks to 250mhz
