My Desire has propped died now
It rebooted while I was just browsing the internet and now it wont go past the T-Mobile loading screen just hangs there Grrr
Any ideas?
Return it to HTC.
Any ideas?
Return it to HTC.
Any ideas?
I had to put Oxygen back on, I've been trying to put CM7 on but it wont work.
It gets stuck on the Why So Serious S-Off page
I've tried using Rom Manager and its the same thing.
What do I do?
Yeah, I was just thinking about that!
I tried to Flash the new HBOOT but I just couldn't get it working
I have just found this on XDA though http://forum.xda-developers.com/showthread.php?t=794638
May have to give it a try
you can tell what hboot your on in bootloader, if its the oxygen hboot no other rom will install afaik, i tried that utility couldnt get it to work, fastboot command is really easy
That Utility appears to have worked and I am just on the CM7 boot screen! Huzzah!
Turns out I do have one problem, I cannot update my radio.
The radio is 32.54.00.32U_5.14.05.17,
I flash the Zip, and then restart but every time it says that there is no space left. I definitely have the new HBOOT table though
Thanks for your help btw!
fastboot flash radio radio.img
I see LeeDroid is up to 3.03 now. I installed it the day after the v3 release and there were some problems with some apps not working correctly. Can anyone comment on how it's handling now?
