- 27 Dec 2009
- Gillingham, Kent
After taking me half an hour last week to simply fit a new HDD to my PC, I have finally admitted to myself that I have outgrown my current Antec 900. While everything fits in there, it's all quite tight and fiddly and cable management is a nightmare. Here's my current setup:
i7 2600k
Asus P8P67 Pro
Zalman CNPS9900 MAX
Hiper 880W Type-M (non-modular)
2 x XFX 5870's (the ones with the power connectors at the back, rather than side)
2 x SSD (128GB C300 + 128GB Kingston V100)
2 x WD 500GB HDD
1 x DVD-RW
1 x BD-ROM
Now I know this isn't a huge amount of hardware and it does all fit in the Antec 900, but it's very cramped around the GPU power connector + HDD area, and the area in front of the PSU is awash with cables. I just think I need something a little bigger and with better cable management. I use the PC almost exclusively for gaming and I love Crossfire setups (I went from 2 x 4870's to a single 5870 to save power and noise - I only lasted a month before adding a second 5870 so it didn't get lonely!).
Because I still like the looks of my 900, I obviously started out looking at the Antec 1200. However, I have recently started looking at the HAF X and, although I'm not as keen on the looks, I am struck by the much better features of the case (quicker drive installs, side mounted HDDs, etc) and the design seems much better thought out than the rather basic 900/1200.
Airflow at a low volume is more important to me than looks, so am I right to be going for the HAF X, or is there another case option I should be looking at? I haven't got a set budget as such, but I don't want to spend £200 if £125 will be nearly as good, and I won't ever be watercooling. Any suggestions or thoughts greatly appreciated.
i7 2600k
Asus P8P67 Pro
Zalman CNPS9900 MAX
2 x WD 500GB HDD
1 x DVD-RW
1 x BD-ROM
