Hi all,
I'm looking to add some more bass to my e36 coupe. At the moment I've got an underpowered single JBL 15" - real budget sub which was a temp measure in the car. So I've gone out and bought a set of JL Audio 12w3 D4's. I don't want stupid bass, or want to spend stupid money so I didn't bother looking at the W6's and W7's.
I'm in a bit of a dilemma as to which amp to use to run the lot.
The specs of the subs are 300W RMS each, dual voice coil, 4 Ohm impedance. Full specs below if this makes any differene:
http://mobile.jlaudio.com/pdfs/12W3v2_MAN.pdf
Now from reasearching the net, everyone seems to pair 2 of these subs with the JL 500.1 amp, which gives 340w RMS @ 4ohm, and 500w RMS @ 2ohm. I can get this amp, but the other one which caught my eye was the JBL GTO 7001 which is rated at the following:
425 watts RMS x 1 channel at 4 ohms
700 watts RMS x 1 channel at 2 ohms & 14.4V supply
Max Power: 700 watts at 4 ohms
Which of the two would you get to run the two subs. I'd like to push the subs hard sometimes (read fairly often), but I can't work out which would be the better.
Any ideas please?
Cheers,
Atari
Any ideas please?
Cheers,
Atari
