If I were to buy another one then this would suit me £50 will buy you a Tornado Tank kit everything you need and since you like it another few quid for a small bottle golden Virginia black label from totally wicked depending on how your cash flow is it maybe worth trying one out first as ive bought for a few people of those three out of the four have gone back on the ciggs` however threre were some teething problems getting started for some,an other reason for the TTank is its so easy to use just fill it up and your good to go,have a look on you tube for some demos or on the totally wicked site,any recommendation for a roll up smoker (GV)
TA
If you go for a 5v passthrough dont get a normal attie, you will pop em like sweets![]()
You mean don't use LR atties.
Stick an LR attie on a 5v or 6v passthrough and it's byebye.
LR atties are designed to give a 5v experience on a 3.7v battery. You should only use normal atties on a 5v or 6v mod.
Well done, ive done 2 weeks with 1-2 cigs a day and now done 3 days completly nicotine free. Im using champix tablets which supress the craving but boy its hard, wish i never started.
When do the craving go away? 1,2,3 months or are we talking years!!
dam, i hope this is not at all worse than cigs, no research like cigs i guess?
I hope 10 years down the line they dont say this is worse/who knows then cigs.
Going for the tank kit, gotta stop these cigs, got 2 kids and its doing my head in knowing what im doing and i need to make sure i get to see then when they get older.
try blowing ciggy smoke through a hanky then do the same with vape, not very scientific i know but just shows whats going into your and everyone around you lungs !dam, i hope this is not at all worse than cigs, no research like cigs i guess?
Not had a cig for about 5 days and i feel terribleSOre throats, blocked nose, always thirsty!
daaaaymnn
daaaaymnn
I did 11 months smoke free and ended up smoking all over the Easter break. Annoyed at myself, but off them again...
