Poll: 6÷2(1+2)
6/2(1+2) = ?
  • 9
    Votes: 516 68.9%
  • 1
    Votes: 233 31.1%
  • Total voters
    749
Bidmas is clearly fallible if people are justifying an answer of nine with it.
6÷2(1+2)
6 is ONE term.
2(1+2) is ANOTHER term.
In order to achieve a result of 9 you would need:
6(1+2)÷2
It is entirely possible this problem was introduced to highlight the flaws of the BIDMAS rule.
wrong, wrong, wrong WRONG!
I see your A* at GCSE and raise you an A at A-Level and a maths degree :p
Unless I'm misunderstanding something in what you're saying, you're finished with the brackets once you have worked out the contents.
6 / 2 * (1+2) is exactly equivalent to 6 / 2 * 3
i raise you're degree and A level with the correct answer. 1.
Can anyone doing a PhD or MSc in mathematics or a related degree give an opinion.
I appreciate some people are using order of operations rules to justify various answers however I have an inkling this problem is a special case used to highlights the flaws of the procedure.
I don't think Mathematica is wrong.
You don't get asked to do something like this above school. You don't get such ambiguous sentences in Mathematics because when you use the / operator you wrap the nominator and denominator in brackets.
I find it easiest to explain by introducing X into the equation
6÷2(1+2) = X
2(1+2) = 6X
2+4 = 6X
6 = 6X
1 = X
It has been a long long time since i've ever done any math though.
Forgive me here but were does the 4 come from? ( 2+4=6x )
B Brackets first ------------- 6÷2(1+2) -----> 6÷2(3) ----> 6 ÷ 2 x 3
O Orders (ie Powers and Square Roots, etc.)
DM Division and Multiplication (left-to-right) -- 6 ÷ 2 x 3 ----> 3 x 3 ----> 9
AS Addition and Subtraction (left-to-right)
Well, what do you know, it is 9, assuming the left to right rule is right.
I was always taught that multiplication always came before division.
i love these threads
always bring out the people who dont know what theyre on about but pretend that they do
tip for those saying 1 ... stick it in your calculator
It's a misunderstanding based on the fact that there is no explicit multiplication sign between the 2 and the (1+2) and therefore people are making the assumption that they should treat them as one term IMO.
Similarly, you could have the equation x / 1 * x and ask it is equal to x^2 or 1.
Applying the order of operations correctly the answer is x^2, but I would imagine lots of people who are saying the answer to your original question is 1 would pick 1 here as well, even though there is nothing in the equation that says I need to calculate 1 * x first.
wheres all this '2(1+2)' coming from? 6÷2=3!!!!!! not 2!
and how do you do that ÷ symbol i always have to use / for divide
(and before quoting me i copied and pasted the ÷ into this post so don't say 'you did it!') :D
As there is no operator in 2(2+1) people are assuming you do the whole thing to work out the bracket. In reality you don't, it's 2x(2+1), so 2x3. In the whole equation this would not = 6 as the division is first, making it 3x3.
Unless I'm doing something wrong, which is possible :D
Honestly, I think a lot of people who aren't stupid with maths would go for 1 - I instinctively turned that ÷ sign into a /, which would be:
6/2(1+2)
Which definitely is 1.
The confusion comes when some have learnt BODMAS and others have learnt PEDMAS. The latter states division comes after multiplication.
