- 10 May 2004
- Sunny Stafford
BUT THATS NOT STANDARD ORDER OF OPERATIONS YOU INNUMERATE PEON![]()
Charming.
Plus, you wrote "thats" where it should be that's or that is. You, illiterate
Apparantly the dictum of this thread so far is that if you think the answer is anything other than the Preschool-Approved '9' you are "retarded".Charming.
They say in the latest prints of the dictionary the word gull... oh nevermind.Plus, you wrote "thats" where it should be that's or that is. You, illiterate![]()
Well he's probably the most intelligent and competent person I know, so I'm going with him on that it's ambiguous and I don't care what any randomer from GD says![]()
Why don't you just work through it yourself? Perhaps ask your amazing genius flatmate to revise the standard order of ops and do it himself.
I'm sure you are capable:
Hahaha, it doesn't help that someone has been editing the Mnemonics section on the wiki article to change the correct answer for this very question from 1 to 9 today either.There isn't. We weren't taught the standard order of operations at school - we were taught an order of operations (BODMAS, etc).
This is the standard: http://en.wikipedia.org/wiki/Order_of_operations#The_standard_order_of_operations
If your teachers taught you BODMAS and called it the standard order of operations, they are wrong and just because someone has told you an incorrect fact does not require me to pander to it.
Well, read all my posts in this thread and see if you think I have made any blind conclusions. I even admit I'm wrong on something earlier on.There is no need to just blindly accept what someone you perceive to be intelligent says.
This isn't complicated.
1/2x = (1/2)x
1/2x != 1/(2x)
That is how the '/' symbol works - it isn't ambiguous. Confusing to some (and parenthesis should really be used in both cases to avoid this) but not ambiguous.
Or in simple terms - if you want the answer to be 1 then you'll need to add brackets.
http://www.wolframalpha.com/input/?i=6/2(1+2)
http://www.wolframalpha.com/input/?i=6/(2(1+2))
Well the standard way would be that it = 9
I hate to see any of your flatmate's production code.
There is no use explaining that. Nitefly is being wilfully ignorant about it. If he worked through it himself (takes 10 seconds) using the standard order, he'd arrive at the right answer - regardless of what his genius flatmate says.This isn't really something to debate or have an opinion over - there is a standard way of using '/' and following that it is quite clearly 9.
If you go left to right in GCSE fashion, then yes, the answer is clearly 9.
