I can't 'Check In' on Facebook.
Consigliere
12 Jun 2004
SW17
Samsung Galaxy S.
Can't seem to get it working...i tried using the Facebook Application.
Places > Check In > ......
And then it keeps 'loading' and nothing happens.
Am i just doing it wrong? :o
I tried using the 'Social Hub' but i can't seem to make it work. :(
'Look at me, I'm at xxx and you are not'
Mind you that is pretty much the whole point in FB anyway so I guess we should let you off :p
I will either 'Check In' or write an update about it so... :p
Checking in at Hooters is always good ;)
Use the mobile site, it's easier. Some phones are buggy with the Android Facebook App.
Works fine on my galaxy s using the facebook app. Only used it once though, just to try it out.
Have you got the GPS turned on?
Have you moved the FB app to your SD Card, as that can cause a similar fault.
Moving it back to phone storage fixes that...
I didn't realise you needed GPS...i thought you could do it without. :o
You don't need GPS as long as you have wireless networks enabled in the location settings. It get's an approximate location from the mobile network and then fb guesses what's close.
