Variable temperature iron - 30-50W, preferably with changeable tips. At least one fine tip and one flathead.
Sponge, always wet it and quickly wipe the iron on it after each joint.
Get a helping hand. Godsend.
Get a solder sucker for £3 on ebay. Godsend.
Always keep the tip tinned, never turn the iron off without leaving it tinned.
Never put more solder on than is needed in the hope it will fix an already bad joint. Desolder and start again.
That's about it really. The rest is just practice.
^looks like some good advice, bullet pointed, just how i like my tips and hints
so higher wattage is better it seems, those links i have actually come across, are useful
ok recommendations for 30-50W variable temp irons?
cheers for all the help so far guys![]()
I'm dubious of your suggestion to use lead based solder. Nasty stuff, especially when you'll probably be breathing it in.
If you're just starting off then you probably don't want to be buying all this kit. Would you know when to change the temperature? No, i stand by my original suggestion of a cheap Antex to learn the ropes with, higher wattage doesn't necessarily mean it's better for beginners.
And i would also stress my earlier point about lead-free solder, make your own mind up about it![]()
If there is that danger of breathing in lead fumes then maybe non lead is besr, anyone else agree?
Dry metal scourer?!
I just use damp tissue which does a perfectly good job without wearing the plating of the tip away. The only time you need something even slightly abrasive is if someone's properly caked the tip in filth.
