People say Driver Sweeper is crap, but thats only because when you search for Driver Sweeper using google for example it brings up Guru3D website they still have the 2009 2.10 version on there.
Indeed, see my thread here for more details: http://forums.overclockers.co.uk/showthread.php?t=18269961Heh, i thought driver sweeper was abandoned ages ago due to that dodgy Guru3D link, it's the frst one that comes up in a search too!. It's so old a build of DS it doesn't update properly either!
I've used it to switch from AMD/ATI to Nvidia Drivers, back to AMD/ATI and updated last 3 months worth of AMD/ATI drivers without any problems, Driver Sweeper working great.Interesting link, thanks!.
FWIW the new driver cleaner works flawlessly on my win7 pc, ATI 5770 & AMD phenom II X4 965 BE.
I'm running this system:
5870
965BE
crosshair IV
4GB Ram
Windows 7 64bit
In all honesty, I'd just bin my Windows install and start again. Who knows what has been ruined and how many more hours will need to be wasted in an attempt to fix.
I'm amazed at the number of people still using driver cleaning utilities.
It just isn't needed.
I've never done a wipe on a multi hard drive machine before, what happens to the programs I've installed on my secondary drives?
i have never ever had any problem from ati's driver or ccc,everytime a new version is out i download it then go to control panel & delete ccc & driver once done & rebooted i then install the newer version !!!![]()
My Nvidia GPU's & drivers are working great......Hint Hint
