I just compared the specs of that with my current card, and my current card has a higher core speed and the same type of graphics RAM, so I dont see how upgrading something that I know I don't need to upgrade would help with my memory issues.
I feel i need to upgrade my RAM because my memory gets maxed out constantly, and i'm pretty sure the memory being maxed out isn't something to do with my graphic card.
Also, I don't trust ATI, had too many issues with them in the past to trust them.
Vesper,
If you're intent on spending £100 you should get this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-259-SP
It will do far more for your game playing than tinkering with your RAM.
It's an alright card, but can only handle 1 monitor, though my current card works perfectly fine.
I use 2 monitors, always have, from the specs of that card it can only handle 1 monitor and that's no good for me.
I'm not sure which you're referring to but the HD 5850 can work with 3 monitors (with the right connections) and the GTS 250 with 2.
1 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
I need 2x of the Dual-Link DVI-I for my monitors. the HDMI is nice I can plug that into my HD tele, but it would stretch across the room.
I could return it if I'm not happy with the results.
I don't know where you're located but if you go into the shop and buy it you won't be able to return it.
If you buy it mail order, and notify OcUK within the time period allowed by the Distance Selling Regulations (7 working days from the day after the day you receive the goods), then you can return it even if it's been opened.
clock speed has zero to do with anything.
8800GT vs 5850 - http://www.anandtech.com/bench/Product/178?vs=164
the 8800GT was renamed to a 9800GT and a 9800GT was renamed to a GTS250, with a few minor tweaks along the way.
