- 30 Apr 2011
Hi
I am about to embark on my first pc build and could really do with some advice from your knowledgable selves. I have looked through the guides and reviews but am suffering from information overload and would really appreciate it if you could give me a bit of help here..
My PC will be used for games and digital art using Corel Painter and similar. My aim is to be able to play existing games at high settings and to look forward to forthcoming releases (Battlefield3, Skyrim, etc) knowing I can play them as they are supposed to be.
While I want games to run well at high settings I am not bothered if one card gives 80fps while another gives 85. I don't want to get too bogged down in stats if you see what I mean, just as long as things look good and work smoothly.
My present pc doesnt have much I can salvage, although I am hoping to be able to use the PSU (OCZ Modstream 450W) to save a bit of money and maybe the hard drive.
So what I am looking at at the moment is something like
Asus M4a77t motherboard (Or similar £60ish board I want a full size atx for reasons I am not sure of)
AMD Phenom 2 x4 quad core 955 processor
about 4 gb ram (to be honest I just plucked this from the sky)
gtx 460 or HD6950 (seem good at around £140 and could be doubled up in future?)
Antec 300 case (simple and only £45)
Or maybe the Intel equivalent i5 processor and whatever motherboard comes in at around £60.
I am hoping to build something that I can upgrade in future with new graphics cards or a bit more ram rather than needing new processors and motherboards for a good while. I was set on the AMD from a price and upgrade point of view but some things I have read lead me to believe that I would be better off with intel for a bit more money.
Anyway. I hope this makes sense (my 1st post on anything ever). If anyone can help me set my mind on at least a few components then I think I can work from there although I will probably have many more questions as things progress...
Thanks in advance...
