i have a 7 speed dsg in my vw golf 1.4tsi, i think its quite brilliant, dont feel a gear change, its also a triptronic box in mine as well (manual and auto) with a sports mode that tends to eat the juice, but makes you grin
Lovely gearbox, just pray it doesn't go bang!. A replacementis big bucks! :-O
Do they have a tendancy to go 'pop'?
I think there is some sort of control module that's the weak link rather than the actual box mechanicals. £1000+ to replace
Does the Mk5 GTI have a dsg or manual box only,automatic was not an option?
Just see lots of adds saying "Automatic"
I just bought a Mk5 GTi DSG.... there were plenty of auto's when I was looking for my car
Also I think the DSG needs servicing every 40k
I believe it's around £2k if you get it done at a dealer. However there are third party companies that will fix the mechatronic unit for around £300 (as mentioned above)... but you still have to pay someone to remove it and to re-fit it, which can still be fairly costly.
The unit then also then needs to be taught as they are adaptive. The 1st thing dealers do is reset the module and see if that helps. If it doesnt, then they replace the mechatronic unit. This isnt a small job.
Last i heard, there was a high portion of DSG/S-Tronic's failing within 6,000miles or just after the warranty expired.
DSG is Auto, it is the only Auto box available for the GTI
Everyone sensible will extend the warranty anyway.
That's another £500/600
Clearly I must be one of the not so sensible ones then!
Had my Mk5 GTi from brand new (07/05) (73k now) and I am glad I did not extend the warranty. The most expensive thing to go wrong apart from usual consumables tyres, pads, servicing etc has been the electronic fuel pump controller relay (cost me £89) and that happened last month. Apart from that it has been rock solid reliable. My sister has a DSG on hers (06/05) and it has been serviced at 40k, no problems there either.
So yeah every sensible person who wants to waste money on an extended warranty please carry on!
