480 vs 480 soc
It really is.
For £200 you get the stock GTX 480 - which is a fast card, but with the stock cooler it is hot and really quite loud.
For £250 (for the Gigabyte SOC) you get a much faster card (core clock 820MHz vs 700MHz stock) and the custom cooler used by gigabyte is much better than the stock one - as a result it is much quieter than the stock card under load (have a look at this).
Other cards worth a mention at this price range are the GTX 570 and the HD 6970.
It really is.
if you have owned a gtx480 you would find that the 6970 is louder than the gtx480 and hotter .
back on topic: just depends if you have the extra cash spare ;)
It really is.
Thats made me mind up thanks andi
Anandtech beg to differ I'm afraid, the reference 480 is one of the loudest cards you can buy, as well as the hottest, and certainly hotter/louder than a 6970.
480 vs 6970
The Gigabyte coolers, on the other hand, are very good and very quiet, and make the 480 a very good card. One I might be picking up in the near future too, if my student loan finally bleedin' comes through.
You'd have to be mad or deaf to use the stock 480 cooling
run a stock 6970 @50% fan speed then run the gtx480 stock fan @60% and the 6970's fan is louder than the 480's fan ;) , i know i have both cards and have been told the 6970 i have is not faulty it is just hot and loud
No chance is the 6970 louder than a stock 480, my mate sent one back because it sounded like a harrier jumpjet compared to my 6950>70, I ripped him rotten about it.
There was a batch of cards that had the wrong tim on them, or maybe the core is not covered with tim properly.
now now enough of the AMD vs Nvidia........ Nvidia are just better :D LOL jk.............. But seriously they are ;)
Defo go for the SE or the SOC the cooler is worth its weight in gold on that card i have the SE oc'ed higher than the SOC and its much much quieter than my cpu cooler :D
Are SE cards easy to overclock?
extremely lol u just run a program called MSI afterburner and slide the sliders up :D mine is on stock volts too so if i wanted to go higher i can but tbh i can run crysis 2 at 60fps at 1050 i cant recommend the SE enough just to let you know my stats are
Core clock 870mhz
Shader Clock 1740mhz
mem clock 2000mhz
all on stock volts tbh i have not pushed the mem any harder yet as i have had no need to
Also i se the SE is back down to 229 (it was at 249 for a while) Given the amount of SOCs i have seen on here go belly up my weapon of choice would be the 480 SE i even run mine on a 550W PSU as im to lazy to change my psu and its fine
thanks for the advice m8 u've just saved me 20 quid on me new rig
:D no worries you wont be disappointed its a blinding card,it eats anything i throw at it and i dont even have a very powerful cpu (see sig) and it still can run anything i ask
also ignore the reviews about temps getting as high as 100c i really dont know what case cooling or lack of they have. I run mine in a antec 300 with all the fans on low and i cant hit 80 without trying fans are left on auto and 70-75c is my norm in gaming with the overclock applied if i manually turn the fans up to 80% then i can stay at high 60's but i just leave on auto.
If you can go for the SOC version, take it over the special edition. The special edition is just the standard edition with a custom cooler. The SOC edition has cherry-picked components that meet a higher requirement standard than is needed for the others. If a component is not good enough for the SOC, it's used for the special edition or standard edition.
