Need a little help please if u would? pc upgrades!
5 Aug 2006
Northern Ireland
on a budget of 150 pounds and need to upgrade a pc with a DDR2 MBoard, Chip, Graphics card...
been a few years since i upgraded a comp and alots changed lol so really need some kind person to help me :)
can stretch to 200 if need
also needs it play Wow, everquest2, portal2...
massive thanks in advance
Is this out of reach?
Your basketProduct Name Qty Price Line Total
Sapphire ATI Radeon HD 5830 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** £85.99
(£71.66) £85.99
(£71.66)
AMD Athlon II X3 Tri Core 450 3.20GHz (Socket AM3) - Retail £59.99
(£49.99) £59.99
(£49.99)
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) £37.19
(£30.99) £37.19
(£30.99)
Gigabyte GA-M68M-S2P GeForce 7025 (Socket AM3/AM2+) DDR2 microATX Motherboard £34.99
(£29.16) £34.99
(£29.16)
Sub Total : £181.80
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 20.00% VAT : £38.26
Total : £229.56
thanks very much, thats great.
gigabyte board is just cool cos my last one was same make and lasted ages, is it a good one or should i look for another a few more quid higher?
Its a good one for its price, has some core unlocking features too, so you may get lucky and create a quad core cpu.
http://www.gigabyte.com/products/product-page.aspx?pid=3645
Spending a few more quid wont get much more, for features like SATA and USB3.0 you are looking at £70 just for the motherboard alone.
noob alert, aint looked into cores etc so im a lil nooby on the subject, really need to look into that asap
and the g cards looks very good
Core unlocking is a feature you will find in the BIOS, simple enough to use, and if it fails to work, you havent lost anything.
Fixed the motherboard link above, its the right motherboard that the Gigabyte link refers too.
so do i need ddr2 or ddr3 for the board or shall i just scrap my ddr2 for 3's
How much DDR2 do you have?
The second motherboard is a DDR3 one, the motherboard in the spec is a DDR2 one.
(£71.66) £85.99
(£71.66)
(£49.99) £59.99
(£49.99)
(£29.16) £34.99
(£29.16)
Sub Total : £150.81
DPD Next Day Parcel
VAT is being charged at 20.00% VAT : £32.06
Total : £192.37
and reuse your RAM:)
you have two options then.
1)
(£71.66) £85.99
(£71.66)
(£49.99) £59.99
(£49.99)
(£29.16) £34.99
(£29.16)
Sub Total : £150.81
DPD Next Day Parcel
Total : £192.37
using your 2GB of RAM without an easy way of getting to 4GB , unless you buy a 2X2GB DDR2 memory kit which are expensive compared too a 4GB DDR3 kit, and then selling your current ram, this motherboard wont unlock cpu cores.
2)
(£71.66) £85.99
(£71.66)
(£49.99) £59.99
(£49.99)
Gigabyte GA-M68MT-S2 (AM3) Motherboard - Retail £39.98
(£33.32) £39.98
(£33.32)
(£30.99) £37.19
(£30.99)
Sub Total : £185.96
DPD Next Day Parcel
VAT is being charged at 20.00% VAT : £39.09
Total : £234.55
Make the switch to DDR3 now with this 4GB kit, and the motherboard does core unlocking.
