My brothers machine using the Crucial C300 and Asus P8P67Pro is having issues, it's randomly resetting and will occasionally lose the C300 entirely upon cold boot resulting in a kernel power error code 41 in event viewer.
C300 is plugged into the Marvell controller (Dark Blue IIRC) and that is set to AHCI in BIOS.
A little digging around the net shows it could be the drive conficting with the motherboard rather than the PSU which appears to be fine.
Before I go to the trouble of spending time swapping PSU's and imaging the system to a mechanical drive to try and track down the issue can I ask if anybody else has the same two components and are they working ok?
Thanks
Thanks
