Are you going to make any holes in this panel for cables to go in/out of? And similarly on the motherboard panel? Otherwise aren't you looking at some very long cable runs? Or am I missing the point?
I did have a thought though.... With all your expertise with cabling perhaps the smart thing to do would be to effectively break your cables into two pieces, joined with a female/female pair of connectors that sit either side of the motherboard tray. You have a lead that connects the motherboard to the female connector on the MB side and your PSU lead plugging into the other side of the tray. I know this would be a huge amount of work and perhaps I am smoking something but I think it would look really neat.
