noob bought a ssd
26 Aug 2010
Hello
ok i bought on impulse a Intel X25-M 80GB g2 (used)
Ive never had a ssd before so dont really no anything about them.
Just a few basic questions for you guys who have them
are these drives any good
What's trim (do i need it)
Are there any do's dont's with these drives
thanks guys.
TRIM is a feature that is automaically enabled by software via your operating system (Windows 7 pre activates TRIM on install.)
If your motherboard supports it. Use AHCI. You will gain quicker speeds rather than IDE.
Never fragment your SSD.
If i were you to optimize it. Never go under 20% of remaining capacity.
Really, you should do some research on products before buying any technology that you aren't familiar with.
SSD's are fast.
Are the questions to people with SSD's in general or with just that drive you have?
with Trim, windows automatically keeps your SSD in tip top condition and speed.
before installing the OS, format the drive :
http://forums.overclockers.co.uk/showthread.php?p=14378855
and run it in AHCI mode from the bios.
never DE-fragment your SSD
Hello
You might want to Secure Erase the drive to bring the nand back up to factory speed. No telling what the previous owner did to the drive. Hammering it with bench tests all day every day will slow it down considerably.
ive got a asus p8p67 deluxe b2 (waiting for a reply from asus to swap it) so should have that never needed to look at that section on bios before
SSD's are fast.
was a bit drunk when i bought it. so thats the main reason why ive not looked into it.
questions are for anyone with a ssd really
whats secure erase
he probably did do loads of benches with it as his system is very high speck and most people with very high spec computers tend to do lots of benches to show off a bit
Yep, secure erase is a fundamental. Not necessary when purchased brand new mind. As its all alligned correctly ready to install. Just for next time your format, bringing back your SSD to shipping performance, you should Secure Erase. :)
