Router with an additional Nic, pico-psu and USB stick. What happened to it that it needed replacement?
That's what I'd use it for as my current router is a playing up.
Wobbly VGA port
I'm thinking of buying one of these but I'm worried about the noise, I currently have a nas and I want to replace it with something more scalable and versatile like this. Hopefully I will use it as a media store mainly streaming to xbmc. Hopefully I can install a blue ray drive and stream to xbmc on the fly? Is that possible?
Also, would it be possible to swap in my drive from the my old nas easily? I will probably install Linux, on another drive. The drive from the nas is formatted using ext3.
So has no one got both the 5th and 6th (esata and internal) port working together? I've spent a while using a number of different BIOS combinations and my HD on the esata wasn't recognised.
I'm wondering whether it doesn't work or if I have a dud esata cable.
Noise wise I can recommend this machine as it is very quiet. Quieter than a HP ML115 G5 I have, and quieter than a D-Link DNS-323 NAS I have as well.
After 24 hours in use downloading files it was still barely audible from a few feet away in a silent room.
rp2000
Thanks. What about my existing ext3 driven with data on it?
I've never really tinkered with servers but I have a good background with unix so maybe that can help with setup. I'm going to order one of these things tomorrow hopefully!
I struggled to get the eSata going, I thought I'd given the details of what I did earlier in the thread, but alas, I can't find them.
I think I remember that I had to have the eSata drive plugged in at boot, and it was picked up by the bios, then it worked.. I may have also switched modes in the Bios, but it perplexed me for ages until finally I realised it needed to be plugged in at power up!
Pass, not a *nix expert so can only offer generic advice. But from a logical point of view, if you install a *nix OS (or a CD/USB live image) and have 2 drives in the machine you should be able to copy data across if the OS can read write to both partitions/disks, I think EXT3 should be accessible from Linux etc.
Also, could you not just put another disk into the microserver and copy the data from the NAS over the LAN (presumably it can be accessed via SMB or NFS etc?)
rp2000
Thanks. Im currently running on the BIOS with the Russian hack stated in the other forum referenced here (Tim's 7TB media server thread). I know that theres a newer BIOS but I dont think theres a hack for that one.
I've also tried to boot the server up with the esata drive plugged in and that doesn't work. It doesn't even register in the bios![]()
I've ordered an Intel Gigabit CT (EXPI9301CT), but I'm not sure if this will come with a half-height backplate.
Can one get the Intel half-height backplate anywhere?
Or can anyone recommend a source for an ethernet adaptor that will definitely fit in the Microserver?
2. RAM:
Is there a noticeable difference between 2x2GB matched modules, and a 4GB module?
I have two MicroServers which I am using as home servers (in two places),
runnning CentOS-5.6.
I'm very pleased with them; they fill the bill perfectly.
I am so tempted by this deal at the moment...
Umm, you realise that everyone in this topic has done the same thing?
It's a fantastic bargain. Just look at the cost of off the shelf NAS's, you can get 6 drives in one of these.
I know, hence why I posted it in herehowever the deal you guys had, expired didn't it back in December?
This is from another retailer, but still getting the cashback from HP
As AbsenceJam said, HP have consistently been extending the offer for another month; see the cashback page on the HP website.I know, hence why I posted it in herehowever the deal you guys had, expired didn't it back in December?
The cheapest at the moment, as far as I'm aware, is £229.97 including delivery, or £129.97 after cashback![]()
