- 14 Feb 2006
Hey guys is the MSI 6950 2GB R6950-2PM2D2GD5 Flashable. I have orderd 2 of these bad boys . Buy i have read that there is some Rev 2 modles that wont alow it. is OCUK sending out REV2 or REV 1 ?
that is the same model number as mine and i have flashed it!...
When you do get make sure you have a bios switch on, it will be next to where you plug in the crossfire bridge it will say 1 or 2.
When you do flash it make sure it is set to 1.....
ok cool
on another note do i need to connect 2 crosfire bridges or just 1 . or does it make a difference ?
just the one will do.
nope no diff between two, just one but if you want you can connect 2up but it wont make a diff at all. Make sure you use Crossfire birdge tho not an SLI![]()
yep i got one with mine but where you have ordered 2 cards you will get two.
yes it will. The 6950 in CF kick some butt!
here the link to show how much better it will be over the 460, i've used the 6970 as that is what you will be unlocking it to.
http://www.anandtech.com/bench/Product/313?vs=298
What PSU have you got?
i dont have 2 6950 m8 i only have one and it's on my watercool so no noise at all.
When i did have it on air my temps was 30'c idle and 70'c load with fan speed at 35% not that noisey for me but i did replace the stock themal paste with MX-4
i bought a Xenta
Xenta 800W Modular 13.5cm Fan PSU - 80plus Certified 6x SATA 4x PCI-E
good to here, that will be fine..
Can anyone tell me what falsh you used as in volts/clocks?? I flashed my Asus 6950oc with the 6970 bios no probs, then i got a MSI R6950 Stock and flashed this aswell no problem but my computer has started to crash playing BF2 and running 3DMarks.. must be the MSI Card because all was well with the Asus on its own.. Cheers
