MSI 6950 2GB R6950-2PM2D2GD5 Flashable
14 Feb 2006
Hey guys is the MSI 6950 2GB R6950-2PM2D2GD5 Flashable. I have orderd 2 of these bad boys . Buy i have read that there is some Rev 2 modles that wont alow it. is OCUK sending out REV2 or REV 1 ?
that is the same model number as mine and i have flashed it!...
When you do get make sure you have a bios switch on, it will be next to where you plug in the crossfire bridge it will say 1 or 2.
When you do flash it make sure it is set to 1.....
ok cool
on another note do i need to connect 2 crosfire bridges or just 1 . or does it make a difference ?
i dont have 2 6950 m8 i only have one and it's on my watercool so no noise at all.
When i did have it on air my temps was 30'c idle and 70'c load with fan speed at 35% not that noisey for me but i did replace the stock themal paste with MX-4
Can anyone tell me what falsh you used as in volts/clocks?? I flashed my Asus 6950oc with the 6970 bios no probs, then i got a MSI R6950 Stock and flashed this aswell no problem but my computer has started to crash playing BF2 and running 3DMarks.. must be the MSI Card because all was well with the Asus on its own.. Cheers
Do you have Vsync switched on in CCC?
Switch back over to 6950 by switchin the switch back to one and try it then.
